A revolution in the production of sliding bearings: it’s only necessary to apply a layer of metal a few millimeters thick using the powder nozzle to reliably, cost-effectively, and easily protect the large shaft bearings used in ships from wear and tear. O.R. Lasertechnologie GmbH develops and builds robot-assisted laser systems for direct metal deposition (DMD) that take the production and repair of sliding bearings to an innovative new level.
The enormous container ships that now crisscross the world’s seas need powerful drives: diesel engines with outputs of up to 110,000 PS and as many as 14 cylinders. The shaft that drives the propeller has a diameter of about 600 mm, weighs up to 300 tonnes, and rotates 84 times a minute. The shaft rests inside hydrodynamic bearings that are naturally subject to heavy wear. This is because the shaft is in direct contact with and slides over the bearing’s surface. A film of lubricant reduces the inevitable friction, but doesn’t develop fully until the oil pressure rises.
Today, latest-generation lasers can be used with a powder nozzle for direct metal deposition, yielding considerable benefits: the metal alloy is fed in the form of a dry powder via the nozzle coaxially to the laser and melted onto the inside of the concave steel bearing shells. The laser permits accurate partial attachment of the alloy. It is only necessary to apply the expensive alloy to about 20% of the surface using this technique, compared to 100% with the traditional casting method. Use of a laser also saves time and energy, since only a small amount of metal needs to be melted in each case.
The ability to quickly change the alloy and apply coatings of nearly any kind of metal opens up incredible prospects for developing new products. AM enables completely new production processes that are able to flexibly accommodate customer wishes in a minimum of time.
Recently, the Berlin-based company of ADMOS Gleitlager began using a laser system from OR LASER. In addition to having more than 100 years of experience producing cast compound hydrodynamic sliding bearings, it is constantly engaged in improving its products and methods.
ADMOS is now taking a new approach to making sliding bearings: with a robot-assisted laser system, a six-kilowatt fiber laser, and two high-power coating heads in the form of powder nozzles. Something that was impossible with the conventional casting process is now becoming reality: namely the use of copper-based materials such as CuSn and CuPb. One of the many advantages of the new approach is that different materials now bind more firmly to one another. All in all, the new method makes it possible to completely eliminate several steps while minimizing the required finishing work afterward.
Jörg Hosemann, the CEO of ADMOS Gleitlager, is thrilled: “The new laser system opens up a whole new world of possibilities for us: faster production and delivery at short notice, as well as enormous potential for slashing costs. I expect the investment in new laser equipment to pay for itself in no time.”
About O.R. Lasertechnologie GmbH
Producer of Industrial Laser Systems
Since founding O.R. Lasertechnologie GmbH in September 1997, Yhushua Resnik and Uri Resnik have steadfastly pursued the goal of developing new applications for lasers in materials processing and innovative laser technologies for a wide range of customers in the metal- and plastics-processing industries.
The company’s comprehensive portfolio of products is the outcome of unceasing efforts to build on and apply many years of practical experience in the fields of laser welding and cladding.
Development and manufacture of laser equipment in Germany for companies that include Siemens, Bosch, Geberit, Freudenberg, and General Electric.
Solutions for the automotive and aerospace, mechanical engineering, electrical, medical, plastics, and tool-and mold making industries
Managing directors: Yhushua Resnik and Uri Resnik Own branches: 6
International distributors and customer service providers: 30 Employees in Germany: 70
RD department: 20 staff
Market share: 25% worldwide across all relevant industries
Contact Data
O.R. Lasertechnologie GmbH Dieselstrasse 15
64807 Dieburg, Germany Phone: +49 (0) 6071-209 89 0
Fax: +49 (0) 6071-209 89 99
web: www.or-laser.com
Email: [email protected]
US Office
O.R. Lasertechnology Inc.
1420 Howard Street
Elk Grove Village, IL 60007
Press Contact
Eric Herrmann
Phone: +49 (0) 6071-209 89 – 38
