Customer Testimonial by Lubrication Engineers:
Monolec® Extend EM Grease (1282)
Waste Management / Alliance Landfill – Taylor, Pa.
Toshiba 300-hp Electric Motor
• Reduced operating temperatures by 15-20°F (8-11°C)
•Eliminated bearing failures
Customer Profile
Waste Management’s Alliance Landfill is a municipal solid waste landfill. When waste is disposed of in landfills, it decomposes in a biological process and produces methane gas. This gas is collected through a system that includes wells, collection pipes and compressors. Since June 2010, Alliance has been piping the gas to a nearby power plant as a renewable energy source, creating enough electricity to power up to 20,000 homes every day.
Application
Four compressors with Toshiba 300-hp electric motors are used to move the gas through a 19-mile pipeline from the landfill to the power plant.
Challenge
Using a commercial grade grease was causing high operating temperatures, resulting in multiple motor bearing failures.
LE Solution
Kevin Chapin, LE lubrication consultant, recommended Monolec® Extend EM Grease (1282), which is formulated with polyurea thickener and designed for use in electric motor bearings or in other applications where polyurea grease is recommended. It offers superior mechanical and structural stability for long service life. It features low bleed characteristics, excellent pumpability and great oxidation resistance.
Results
Other Products Used
• Almaplex® Industrial Lubricant (1274)
• Perma® Star Vario single-point lubricators
• Bijur centralized lube systems
Visit www.le-international.com for more information about Monolec® Extend EM Grease (1282)
